Re: How to get it out with---
Posted by Tom Windsor on July 15, 2006 at 20:07:12 from (152.163.100.65):
In Reply to: Rookie Mistake (H Carb Rebuild.) posted by Elk Farmer on July 15, 2006 at 06:42:13:
Your question is how to get it out without breaking anything else. I assume that the top piece is out and the lower part of the venturi is sticking into the bottom half of the carb...
With stubborn pieces such as this, you do have to be real careful or you will tear something else up...I would apply heat to it and see if that will not loosten the corrosion between the aluminum and the iron casting...I have had success with broken off screws, plugs etc with heat on the carb.
