Re: Super M clutch pedal
Posted by Janicholson on July 16, 2006 at 19:32:45 from (66.173.50.187):
In Reply to: Super M clutch pedal posted by Fancy Farm on July 16, 2006 at 19:22:57:
It can be done easily by a machine shop. put a hole in the "oilite" bushing for grease. If the shaft is worn, it can be built up and turned down. Sombody just never greased the pivot. JimN
