Re: Super C Front Hub Conversion
Posted by Hugh MacKay on July 17, 2006 at 16:49:05 from (209.226.106.96):
In Reply to: Super C Front Hub Conversion posted by Stiles on July 17, 2006 at 11:36:21:
Stiles: You can go to most any reputable bearing shop with you old hub and he can match up your axle with a hub that can be ordered to suit a particular wheel. You can probably take most any car hub to him that has roughly same dimensions as your SC hub, and he'll be able to fix you up with bearing and seals.
Now, for half the money, you can call Miller Tire, he will fix up with a new set of Super C front rims right to factory specs. Your old rims are rotten. You take the new rims, install new tires, put in 30-35 lbs air, bolt rims tightly to hubs and I'll guarentee you, "You are not man enough or rugged enough to stay with the SC long enough to bend rims. You will break bones and front end off tractor before you bend new rims.
