Re: 51 farmall C
Posted by CNKS on April 10, 2009 at 13:57:11 from (216.144.104.128):
In Reply to: 51 farmall C posted by burnsg2003 on April 09, 2009 at 20:48:09:
RPM is definitely 1815, it is in the operators manual. I hope OEM has improved their act on serial plates. 5-6 years ago they weren't very good.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
