Re: ihc 400 with prestolite distributor
Posted by Bob M on July 18, 2006 at 07:17:29 from (151.190.254.108):
In Reply to: ihc 400 with prestolite distributor posted by jim ball on July 18, 2006 at 03:03:01:
Jim - I'm not familiar with the Prestolite dist on a Farmall. However if you set the points at .018 - .020 it should work fine. Then set the static timing at 0 deg (ie. top dead center).
With an oddball distributor and the loader stuff in the way, your 400 sounds like a good candidate for electronic ignition!
