Re: SC klunk
Posted by Brownie 45 on July 18, 2006 at 11:07:45 from (207.177.82.15):
In Reply to: SC klunk posted by Red Agony on July 18, 2006 at 06:07:54:
Jack the tractor up, & roll the wheels slowly & listen for any noises & where they come from. Same for front wheels. If nothing found, block the clutch forward,& put the transmission in gear & roll the rear wheels while listening for noise. On our 450, a broken brake return spring occasionally got wedged between the brake housing & movable disc, & made noise bad enough that we thought it was an axle bearing. We even pulled the axle & checked the bearings before finding the spring. Might save you some time & trouble.
