Farmall Tractors Discussion Board
Re: Starting fluid
Posted by Bob M on January 21, 2000 at 11:17:00 from (192.232.120.194):
In Reply to: Starting fluid posted by Rollo on January 21, 2000 at 08:15:36:
Occasional use of ether for an emergency start shouldn't hurt your H. But ether can detonate pretty hard inside the motor - regular use is tough on head gaskets, rod bearings and the like.
If your tractor is properly maintained it will start without difficulty at least down to -20 degF without ether. The better cold starting strategy is to make sure your carb, ignition and lube systems are in good working condition.
Post A Followup
: Re: Re: Starting fluid
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
