Re: 460 ute or 574
Posted by FromJB2 on July 18, 2006 at 18:53:16 from (69.198.143.165):
In Reply to: Re: 460 ute or 574 posted by catmandoo on July 17, 2006 at 20:07:54:
Hi catmandoo, Re replacing the parking brake band:
My brother's 684 has the same problem, he asked a former IH mechanic about replacing the band and here is his answer: It is not worth replacing the band without replacing the drum as the drum will be scored and the new band will not hold. To replace drum requires many $$ splitting tractor at rear and taking top off where seat and 3 pt hitch sit on transmission.
His simple solution is to buy all thread bolt with eye on end, drill a hole on floor board and mount bolt so eye of bolt comes up between brake pedals. To park tractor press brakes down and put a pin thru the eye to hold brakes on.
Works great.
JB2
