Re: 460 motors
Posted by migraine on July 18, 2006 at 21:15:08 from (71.231.54.158):
In Reply to: Re: 460 motors posted by Gary in Mozarks on July 18, 2006 at 21:06:55:
236,282,301 are all the same block just different bore amd crank. I pull a 460 turbocharged about 290 cu inch and I think thats about all that small rearend and axles were made for. Probably would have trouble getting a 361, 407 or 414 into the space betwen the frame rails but I suppose it could be done but check what the rules are for your pulling club or area. They might call for the original block and other limitations. Migraine
