Re: 1946 M - Low Compression????
Posted by Fiddle Man on July 19, 2006 at 04:06:04 from (12.150.136.130):
In Reply to: Re: 1946 M - Low Compression???? posted by Magman on July 18, 2006 at 18:48:40:
I have cleaned all the connections. Based on past experience, the 6 volt battery spins the engine well enough that it should start without having to pull it off. Last night I squirted some Marvel Mystery oil into each cylinder. I'll let it set for a day and see if the compression comes up any with the throttle open. I'm hoping that maybe the rings are just stuck and need to be freed up to reseat. Fiddling with old iron is a joy and a pain in the #### at the same time!
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
