Re: H Farmall Case Seal
Posted by Wayne Swenson on July 19, 2006 at 05:57:45 from (71.13.41.123):
In Reply to: H Farmall Case Seal posted by Billy S. on July 19, 2006 at 05:44:06:
Both transmission drive shaft & PTO drive seals are located behind the belly pump.
Remove the pump & the PTO seal is right behind where the pump drive connector is located. remove the connector. Put the transmission in reverse & lock the brakes. Use a bar or pipe wrench to unscrew the drive lug, lefty-loosey.
Remove the 3 cap screws & the housing comes off with seal attached. Replace the seal & gasket, replace the 3 cap screws, screw the drive lug in, righty-tighty, & you are done. Some oil will leak thru the bearing while you are replacing the seal.
Transmission drive is similar but you must remove the drive shaft coupler to get at the seal. Tip: when the nuts are off the tapered bolt, hold the coupler drive with a pipe wrench & turn the tapered bolt to loosen. Don’t try to drive it out or damage will happen.
