Re: off the wall Question!
Posted by Janicholson on July 19, 2006 at 08:43:13 from (199.17.6.122):
In Reply to: off the wall Question! posted by Marty Johns on July 18, 2006 at 18:22:50:
These units have two problems Fuel and Spark. If there is no spark, it needs the mag system replaced or adjusted. If it is the fuel there are two issues, the fuel lines rot to look like black goo, and the diaphram needles wear and fail to control the amount of fuel entering the engine. Both are fixable with a carb kit, and or new vinyl tubes. Fix the one with the best compression!!. JimN
