Re: finding dipsticks on Hydraulics
Posted by IH2444 on July 20, 2006 at 07:26:58 from (192.76.82.89):
In Reply to: finding dipsticks on Hydraulics posted by Dean D on July 20, 2006 at 07:00:23:
If it is like my 2444/444 then there is a plug on the side of right hand side of tranny. Fill till fluid comes out that plug.
Does yours only have the one engine mounted hydraulic pump ? If it also has a front mounted pump driven from the front crank pulley then the level is 6 inches down from the top of the filler plug beside the shifter. Which is about 5 gal more than without the auxilliary pump.
There is also a suction screen on the end of the suction line where it goes into the lift box on the rear of the tractor. This could be plugged causing poor hydraulic performance. Or water in the fluid ?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
