Re: Logic: Swinging Drawbar?
Posted by Andy Martin on July 20, 2006 at 07:44:48 from (64.219.39.195):
In Reply to: Re: Logic: Swinging Drawbar? posted by Allan In NE on July 20, 2006 at 07:00:52:
The only time we ever unhooked it was using a disc. If the disc is really sunk in it's a little easier to turn but if you don't watch what you are doing it is all the way to one side and the disc is trying to climb the tire.
After you get your first furrows with a one way you can unhook the drawbar and it will track right well. If you try to pull a one way somewhere it does not wnat to go it just slides the tractor tires sideways and you lose a lot of traction.
