Re: Logic: Swinging Drawbar?
Posted by Don L C on July 20, 2006 at 08:40:29 from (24.166.244.128):
In Reply to: Logic: Swinging Drawbar? posted by City-Boy McCoy on July 20, 2006 at 03:36:47:
Hi City Boy ---
Back in the days of drag type equipment the swinging drawbar made it easer to turn at the end of the field......the tractor could make most of the turn without the restance of the equipment it was pulling.....helped while disking mostley.....some time tou had to add a little break on the wheel side you were turning.....
hope this helps Don
