Re: Camshaft lobe height on an H
Posted by Brad in WI on July 20, 2006 at 11:53:34 from (24.208.27.54):
In Reply to: Re: Camshaft lobe height on an H posted by Magman on July 20, 2006 at 11:42:08:
I work in a machine shop where I can set the cam up in a lathe and by using an indicator measure the height and sides of each lobe. I glanced through the I&T Manual and did not see the lobe height but did find the journal diameters.
brad
