Re: Camshaft lobe height on an H
Posted by Janicholson on July 20, 2006 at 11:58:40 from (66.173.50.168):
In Reply to: Camshaft lobe height on an H posted by Brad in WI on July 20, 2006 at 10:07:35:
Cam regrind shops will know that spec easily, If it is better performance needed, use a 350 cam. (or specs) JimN
