valve cam rods
Posted by Gary H1 on July 20, 2006 at 18:48:30 from (66.211.207.239):
I have got a lot of information off this board thanks. My 230 was not running right missing on one cylinder. Number 3 had a fouled plug. I checked to see if plug was firing and it did. Next I did a compresson check 1-2-4 at 150 psi 3 at 60 psi.Next I pulled the valve cover and the 2 rods on the cam tappet to rocker arm were bent one was not even on the rocker arm on 3 cylinder. The valves are free so what would make them bend? Also can I just get 2 new rods or should pull the head and have the valves redone?
