Re: Super A 6V vs 12V Condenser?
Posted by RustyFarmall on July 21, 2006 at 07:46:54 from (216.248.75.141):
In Reply to: Super A 6V vs 12V Condenser? posted by City-Boy McCoy on July 21, 2006 at 07:30:40:
Someone will correct me if I'm wrong, but I think ALL points and condensor ignition systems are 6 volt only. This means that your 12 volt coil will, or should, have an internal resistor which drops the voltage to the points and condensor down to 6 volts. Generally speaking, when a condensor goes bad, it just quits. You might try touching the coil when the tractor starts running rough and find if the coil is hot. A coil will be warm to the touch, but should never be hot.
