Re: Rear axel bearing help
Posted by Aces on July 21, 2006 at 09:02:58 from (65.54.97.194):
In Reply to: Rear axel bearing help posted by newpuller on July 21, 2006 at 08:25:06:
newpuller If the bearing is as bad as you say, you might grind 2 screw heads flate on 2 sides to get them through the bearing race then trun them 1/4 trun and pull the bearing out. If it were me and going to use or pull the tractor I would replace iner bearing. Not hard job, yoi got tire off or will have. Drain rear end remove pto take cap screw out of axel that holds bull gear remove washer and put cap screw back in use a plock between screws of each axel and crew the srew back out pushing againest other axel. Then use bar to pull bull gear back and slid back of bull gear to one side and you can get at inner bearing to replace. If you need more info ask.
Aces
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
