Re: Super A 6V vs 12V Condenser?
Posted by John T on July 21, 2006 at 12:00:09 from (66.244.90.5):
In Reply to: Super A 6V vs 12V Condenser? posted by City-Boy McCoy on July 21, 2006 at 07:30:40:
McCoy, I agree with Bob. The condensors Voltage Withstand rating is farrrrrrrrrrrrrr higher then 6 or 12 volts anyway, soooooooooooo an off the shelf condensor wouldnt likely be any different if for a 6 or 12 or heck even a 24 volt system etc., CUZ THEY ARE RATED WAYYYYYYYYYY HIGHER THEN ANY OF THOSE VOLTAGES ANYWAY.
The condensor is more of a current and energy absorbing passive device then anything thats voltage related or voltage sensitive or voltage dependant. Its job is to prevent premature burning up of the points and it does that by serving an as empty well/bank just sitting there waiting to accept the inrush of electrons that occurs when the points break open and the coils current reallyyyyyyyy wants to keep flowing somewhere, and its absorbing of them prevents as much arcing n sparking across the points which would quickly burn them up.
NEXT some coils are labeled "12 volts for use with an external ballast resistor" and if so they are in reality a 6 volts coil in which case an external voltage dropping (12 to 6) ballast resistor is required or else the coil overheats and the points burn up quickly. A true full 12 volt rated coil (some call internally ballasted) is labeled 12 volts or else 12 volts NO ballast required,,,,,,,,,, Soooooo if thats the coil you have (true full 12 volt) dont use any ballast. HOWEVER if otherwise add one.
Its possible that condensors can break down and especially when they warm up, so since they are much cheaper then a coil anyway, Id try a new one if in doubt. If she still has problems after warm up then Id suspect the coil or the points among other things.
Hope this helps understanding of the condensor and why one used on a 6 or 12 volts system is most likely the exact same thing. Its NOT true that all condensors are 6 volts, they have a voltage withstand rating muchhhhhhhhh higher then 6 or 12 anyway as the voltage spike across them when the points break open is also muchhhhhhh higher then that as Bob explained.
Take care yall n God Bless
John T Retired Electrical Engineer
