Re: Still need help
Posted by Dave Slater on July 21, 2006 at 15:20:05 from (205.188.116.133):
In Reply to: Still need help posted by newpuller on July 21, 2006 at 14:05:25:
If your replacing inner and outer axle bearings and don't want to remove transmission cover.Drain oil remove PTO,jack and block up rear,looking in PTO hole there will be a 3/4 inch bolt and big washer in end of axle.Put a wrench on it and use wheel for leverage and turn axle to rear for right side until bolt is loose.Remove wheel,put something under bull gear to keep it from droping down,remove 7 bolts on outside of axle housing and remove from tractor.Remove 4 bolts from cap on end of axle and remove axle from housing.Remove 4 bolts and 2 plates that hold inner bearing to remove. If just replacing outer bearing the axle housing can be left on tractor and a push bolt can be rigged up to push axle out.If you don't want to lift housing and axle togeather you can take axle out and then housing like that if replacing both bearings.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
