Re: Haul or drive?
Posted by Nat 2 on July 21, 2006 at 22:04:39 from (64.80.108.52):
In Reply to: Haul or drive? posted by BOBM25 on July 21, 2006 at 10:32:05:
One thing you might want to consider is fuel. Truck/road diesel is not the same as tractor diesel, and you'll probably only be able to get road diesel at 99.9% of the stations you pass along the way.
Now this is only nasty rumor at this point, but I have heard that running tractor diesel in a road vehicle will tear up the injector pump and injectors. The same may be true for running road diesel in a tractor.
Unless you bring your own supply of fuel, you may well spend well more than $1200 on fixing your new tractor after you've had it trucked to the local mechanic instead of to your homestead.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
