Re: Farmall A/B rear axle
Posted by Hugh MacKay on July 22, 2006 at 02:07:04 from (216.208.58.134):
In Reply to: Farmall A/B rear axle posted by LloydB on July 21, 2006 at 18:52:15:
Lloyd: The cast extension can be removed, you will need the shorter axle shaft. You will have to change the left brake linkage. Once you have that, the final drive will bolt right up to the rear end.
