Re: H 4 mag coil
Posted by Bob on July 23, 2006 at 13:05:54 from (64.21.249.40):
In Reply to: H 4 mag coil posted by Paul G. in Mn on July 23, 2006 at 12:58:13:
YES, it should "beep". NO, it does not indicate a bad coil.
With the breaker points OPEN, the coil's primary winding is connected to ground at one end, and the points/condensor at the other end, so the meter WILL show conductivity to ground, through the coil's primary winding.
It is IMPOSSIBLE to accurately evaluate the condition od a coil with an Ohmmeter. Yes, and Ohmmeter will catch a DEAD short, but even one shorted turn in one of the coil's windings will greatly reduce spark output.
Coil are tested with a machine that RINGS thme with and AC current, and displays the condition of the coil depending upon how it RINGS (oscillates).
Think of a "good" coil as a bell that rings when struck.
A "bad" coil is much like a cracked bell that gives a dull "thud" when struck, instead of a bight note. A shorted or partially shorted coil acts the same way, electrically, and that is what the coil teater displays.
