SMTA Throttle Assembly
Posted by GordoSD on July 23, 2006 at 14:11:58 from (66.115.200.140):
The throttle assembly on my 54 SMTA is in real bad shape. Need to replace/rebuild it. It has the saw teeth in it. I have seen some with a square notch plate. Which one should I go shopping for and why?
Gordo
