Re: casting dates
Posted by Dave Slater on July 23, 2006 at 14:48:56 from (152.163.100.65):
In Reply to: Re: casting dates posted by Jim Becker on July 23, 2006 at 11:53:27:
I agree the lower starting # is more acurate. 3 I have had MD 285266 , MD 285597 and 286713 Gas all had most castings in 52. Example MD 285597 Transmission 2-9-X , Center housing 10-2-W , R Axle 1-18-X, L Axle 2-13-X, rear wheels 2-5-X and 2-6-X, Engine Block 11-21-W, Lower bolster 2-18-52, Trans. top cover 1-X, upper bolster 1-X . Couldn't make day out on last 2. Head was changed sometime like most, 8-14-D .
