Re: Timing Light
Posted by HAS on July 23, 2006 at 20:33:13 from (68.228.161.160):
In Reply to: Re: Timing Light posted by Andy Martin on July 23, 2006 at 12:47:24:
Right - the ohm meter just gives you a good indication of when the points actually break. You can also use a volt meter from the distributor side of the coil. You will read no voltage, but when the points break, it will read voltage.
