Re: Front Bolster Removal on M
Posted by turbos10 on July 24, 2006 at 03:54:02 from (76.0.73.96):
In Reply to: Re: Front Bolster Removal on M posted by CNKS on July 23, 2006 at 13:42:55:
Thanks for the replies. I guess I will plan on waiting to weld the front on until the bolster is out. I guess I will have to block up the tractor on the engine while working on it.
I do realize that I can unbolt the front wheels from the bolster, but I am actually removing the whole bolster and building new light weight steering setup with the wide front. I will be using a narrowed axle from a peanut trailer for the axle itself. I will use either a right angle 1:1 gear box with a rack and pinion setup or use a 4:1 box mounted up high and a long steering rod to go down to the axle. At this point I can not find the 4:1 box, so it is looking like the first option will be how I go.
I need to remove the bolster so I can move weight around. As it is now, I can't even get the front end in the air when pulling in 4th gear. It just blows the tires loose at this point. Plus, I will be able pull it at 4500lb or less if I want to after this.
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
