Re: loping idle
Posted by jal-SD on July 24, 2006 at 08:26:09 from (71.32.34.112):
In Reply to: loping idle posted by dig on July 24, 2006 at 07:25:17:
Did you make sure that the square end of the shaft from the governor got into the square slot on the carb? Your problem is probably as indicated above, but if you missed the slot, it'll do the same thing. (My $0.02 worth. jal-SD)
