Re: Front Bolster Removal on M
Posted by Janicholson on July 24, 2006 at 08:33:57 from (66.173.50.6):
In Reply to: Front Bolster Removal on M posted by turbos10 on July 23, 2006 at 11:50:25:
From the sound of your description, I would recommend that there be two things considered. First, I would recommend the wheels be close together, as they are normally on a narrow front. This keeps the forces on the wheels from twisting the axle and forcing the steering. Second, I would recommend at least 2.5 to 3.5 turns from full left to full right. If there is less advantage the wheel will be too hard to turn. If more it may be too slow in correcting direction. These are not to try to convince you to stop, just avoid broken fingers. JimN
