706 specs transmission
Posted by dw64 on July 24, 2006 at 10:37:25 from (64.118.137.194):
Hi,
Just bought first tractor. 1964 Farmall 706 gas. Still looking for operators manual and had a few questions.
What is best engine oil and hydraulic oil to use? Won"t be heavy use on the tractor.
Also, saw a lot of discussion on the hard shifting transmissions. Mine is difficult in and out of reverse/low. Only adjustment I made was the main linkage and took out some of the free-pedal.
What is the proper procedure to adjust clutch, clutch brake and dump valve???
Thanks...
