Re: 6 volt / 12 volt?
Posted by RustyFarmall on July 24, 2006 at 10:41:21 from (207.32.13.252):
In Reply to: Re: 6 volt / 12 volt? posted by Mike CA on July 24, 2006 at 10:29:18:
I have two Farmall Hs that actually do get used on a regular basis, both of these tractors are the original 6 volt systems, one of them is the newer voltage regulator type of set up, and the other one is the older "cut out relay" style. Both tractors start easily when I want to use them, and neither has ever given any trouble except for having to replace a dead battery. I really don't understand the concept of converting to 12 volt.
