Farmall Tractors Discussion Board
Re: Key switch for H
Posted by Ludwig on January 21, 2000 at 16:58:20 from (216.41.33.245):
In Reply to: Key switch for H posted by Jeff W on January 21, 2000 at 16:23:56:
What about a clamp on lock to put on the clutch lever, or the fuel shut off? They make them for VW bugs that clamp onto the shifter, but presumeably you leave the tractor in gear so he'd be able to run around, just not shift.
Post A Followup
: Re: Re: Key switch for H
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
