Tinwork Tip
Posted by GordoSD on July 24, 2006 at 21:37:17 from (66.115.200.140):
Here's a little tip I picked up from the local body shop guys.
When you have a panel dent you are working smooth, using primer surfacer, and then sanding time after time this saves time. Use a small roller, about 1/1/2 to two inches wide, a foam roller. Dip it in the can or use saved small microwave dinner plastic pans. I don't even clean the roller cartridge, just toss it. Your local auto body shops will have them. No more cleaning spray guns after just a little use.
