Re: Farmall 200 misfires, HELP!
Posted by El Toro on July 25, 2006 at 05:03:14 from (152.163.100.65):
In Reply to: Farmall 200 misfires, HELP! posted by JoMT on July 24, 2006 at 23:02:05:
If you found trash in the gas tank it's very possible some is in your carburetor and your gas line. Need to clean them and blow out the jets.
You may need to soak the carburetor in carburetor cleaner and install a kit. Check the inlet to the carburetor for dirt and a clogged screen.
Having to use the choke is a good indication of
the engine starving for fuel. Hal
