Farmall Tractors Discussion Board
Re: Starting fluid
Posted by IHank on January 21, 2000 at 17:17:45 from (167.142.13.232):
In Reply to: Starting fluid posted by Rollo on January 21, 2000 at 08:15:36:
Heed the good comments in the other posts. In addition, come Halloween time drain the fuel tank (use it up in your pick 'em up) and fill with fresh 'winter grade' gasoline. Fire up and run it around a while to get all the summer gas flushed outta the filter, lines and carburetor. What you descibe sounds like a certain private label gasoline here in Iowa. Switch to 'big name brand' gas in nasty weather.
Post A Followup
: Re: Re: Starting fluid
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
