Re: Visual difference between TD35 TD40
Posted by JerePa on July 25, 2006 at 18:45:39 from (71.54.95.6):
In Reply to: Visual difference between TD35 TD40 posted by C Clark on July 25, 2006 at 04:02:27:
Early TD35's had 4 track rollers. Later ones had 5. The engines are the same visually. Only difference is the bore. The 40 is 8" longer than the 35. 40=140" OAL. My 35 engine number begins with TDB----. Don't know what a 40 engine number starts with. Number stamped on side of the block. Hope this helps. Jere
