Re: Farmall 300 TA
Posted by Janicholson on July 25, 2006 at 20:01:09 from (66.173.50.81):
In Reply to: Farmall 300 TA posted by SLH IN MO on July 25, 2006 at 16:37:16:
The TA is a system for allowing 10 speeds forward and 2 in reverse. It is a planetary (Think automatic trans type gear sets) gear assembly that is placed in front of the 5 speed straight toothed conventional trans. It is operated by a clutch (on this model)that is mounted to the engine and behind the main clutch (complex, but not rocket science) The TA works in direct drive with the lever forward. It works in reduction (about 35%) when the lever is back. The lever is always moved briskly between positions, never slowly. The tractor has both clutches engaged when in direct this causes the TA to act just like a drive shaft, and it does nothing internally. When it is in reduction, the TA clutch is disengaged allowing the planetaries to rotate. The torque reaction of the reduction is directed to a one way clutch which prevents the TA body from turning backwards, and the tractor from doing nothing. The tractor is free wheeling when in TA. This means there is no engine braking and the tractor can roll down hills faster and faster. This can result in a exploded TA if allowed to happen. The operator will hear a whine that starts like a jet engine starting. When it happens, apply brakes, and slow down it is a great way to ruin the TA and expensive. The most common grief is a bad adjustment of the clutches (both) which is easy to fix if done immediatly, Follow the book, Or the Tractor Vets instructions (he is very gifted). The result of not adjusting is to have difficult shifting, and problems moving the tractor (and expensive trpairs if ignored). The second situation is a blown slipping one way clutch. It happens on some, and not on others, (we have a 350U with the original TA and clutches in it and more than 20,000 hrs of rugged use. The third most common issue is a bad TA clutch. this is just a replacement situation from normal wear. The TA is the (argueably) best invention to farm tractors after live hydraulics. It is very powerful in utility value and they do not break commonly if kept in adjustment, and shifted firmly. I hope this is clear to you. JimN
Home
| Forums
Today's Featured Article -
Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
