Re: First Farmall live PTO
Posted by P Backus on July 26, 2006 at 07:57:57 from (69.128.33.245):
In Reply to: Re: First Farmall live PTO posted by Todd in SE Ohio on July 26, 2006 at 06:03:52:
All the balers I"ve ever seen have their own over running clutch,
so they work fine with non- live tractors.
The M&W clutch that Andy mentioned is an aftermarket add on
that simulates live PTO by disengaging on of the drive wheels,
thus stopping forward motion. even though it is still in gear. To
change gears, you still have to depress the transmission clutch,
which will stop your PTO. What are you wanting to do that
requires LPTO? Don"t get me wrong- there are some things that
are much easier with LPTO, but sometimes the M&W isn"t the
answer. Just make sure you know what you want before you buy!
Paul
