Re: Farmall Regular Questions
Posted by Nebraska Cowman on July 26, 2006 at 13:27:15 from (65.169.97.206):
In Reply to: Farmall Regular Questions posted by Hal Davis on July 26, 2006 at 08:50:43:
1.Yes, you will find the seial number stamped in the top of the lefthand frame rail near the radiator.
2.Yes, the front lever is for the spark advace providing yours is still equiped with the correct magneto. The rear lever was for the throttle and conected by a rod to the front of the carbretor throttle housing. It may have been converted to a variable speed governor in which case there will be a notched rod along side the fuel tank to control the governor directly.
3. The radiator would have been covered with a roll-up canvas curtain
4.Oil filters were standard equipment on the Regular about 1928 or 29, If it is a Pur-o-lator it is probably original.
third party image
