Int. 1600 truck brake booster
Posted by markymark on July 26, 2006 at 14:39:10 from (24.210.209.238):
I recently took my booster off underneath the floor of my int. 1600 loadstar..the booster is located underneath the floor .There is a vacuum line fron manifold that runs to it ..well the fitting broke off at the booster and I took it all apart and got the fitting out .I guess I got it back together wrong because now when i start the truck up it lock's rear brakes...If I shut off engine it will roll nice ..soon as i start it up it somehow ties up the brakes..What part do i have in wrong in the booster?
