Re: Difference in M and H dimensions?
Posted by CNKS on July 26, 2006 at 18:06:57 from (204.249.178.138):
In Reply to: Re: Difference in M and H dimensions? posted by Mike CA on July 25, 2006 at 21:33:48:
They are similar in wheelbase and overall width. The M engine is taller and wider, has 248 cu in compared to 152 for the H. The M itself is much taller to the top of the hood. The other dimensions of the H and M are similar because they were designed to use the same mounted equipment. The similarity as to size ends there. Remember it is at least 1000+ lbs heavier.
