Re: 400 quits when gets to operating temp.
Posted by Scott in Wisconsin on July 26, 2006 at 18:58:04 from (66.222.126.87):
In Reply to: 400 quits when gets to operating temp. posted by Scott in Wisconsin on July 25, 2006 at 20:51:30:
The coil makes sence. It"s the one item I didn"t replace. I even replaced the resistor. I"ll probably replace the condensor too just because "Ya never know" and because they"re cheap. I"ve never had to replace a coil, so I guess I didn"t even concider it.
To the contributor who mentioned "worn valves", I don"t think that is it because it is less than a minute from the time it acts up to the when it stops. It isn"t gradual power loss, and it sure does back fire.
Thanks for the info gang. It was a great first experience.
Scott in Wisconsin
