Re: Cub steering
Posted by Janicholson on July 28, 2006 at 10:39:14 from (199.17.6.122):
In Reply to: Cub steering posted by Rich Griffin on July 27, 2006 at 17:14:54:
Tire pressure can be a factor in pulling to one side. A bent axle, or spindle might also cause the symptom. Toe in is less important but a factor to set toe in jack on wheel and use a nail to scribe a line on the middle of the tread(use a jack stand or block to hold it steady while marking the tire/rib. Then do the other side the same way. Let it down. Roll the tractor forward a bit to put the tires in there running location (don't let it backup any or it won't work) then measure between the scribe marks at the front of the tires and at the rear of the tires. front should measure 1/8-3/16 less than rear. The scribe marks take out the tire and wheel mount irregularities) For the bent axle issue, put then tractor on level concrete (or evenly tapered front to back, but definately level (with a level)) and use a level to assess the camber (how much the tire leans in and out from vertical) and caster, how much the front spindle leans back from vertical. You are not interested in a specification, you are interested in having the two sides the same. The camber should be positive (leaning out at the top about a half inch from top of tire to bottom) and the caster should be leaning toward the back about 1/4" on the hight of the spindle. Good luck. JimN
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
