Re: farmall cub gas tank dent
Posted by Bus Driver on July 29, 2006 at 08:45:58 from (66.44.247.12):
In Reply to: farmall cub gas tank dent posted by brad in ky on July 29, 2006 at 05:47:17:
Putting air pressure in the the tank is VERY unlikely to pop out the dent and IS very dangerous. Some have made for themselves special hammers that will fit through the filler neck opening. If it was important enough, I might drill a hole about 3/4" diameter on the opposite side of the tank and use a long rod with end ground to ball shape that I could tap to knock out the dent. Work the outer edges of the dent first. The hole would have to be welded closed. Dangerous on a fuel tank for the unknowing.
