Re: H Carb. Factory Settings
Posted by old on July 29, 2006 at 08:47:00 from (4.245.1.65):
In Reply to: H Carb. Factory Settings posted by DCS on July 29, 2006 at 08:06:56:
The instruction that come with the kit should tell you each of the settings to start with. Then when your done rebuilding it you will need to fine turn them to get your engine to run the way it should. No 2 engine/carb combos will be set the same way due to the fact nothing is made perfect. Plus differant parts on the country make engine run differant
