Re: Repolarizing generator
Posted by Janicholson on July 29, 2006 at 10:27:42 from (66.173.50.100):
In Reply to: Re: Repolarizing generator posted by EH in KS on July 29, 2006 at 08:37:43:
While it is running, run a jumper lead to the small terminal on the gen. while watching the amp gauge, ground the other end of the jumper. If it charges then, it may be that the contacts inside the regulator need to be cleaned, or maybe the reg is not grounded properly. If it does not the gen may need repair, have it tested. Good luck, JimN
