Mounting a 3 pt post hole digger on a Farmall 504
Posted by jessboyd1 on July 29, 2006 at 14:10:21 from (24.119.127.117):
I just bought a Leinbach L-7300 3 point hitch post hole digger. The yoke is not "tall" enough to lift the digger gear box high enough to let the auger become plumb vertical. Has anyone else had this problem? What did you do about it? (It looks like if I extend the length of the yoke about 5 3/4 inches it will lift it high enough.) I called the guy I bought it from ( he has sold 50 to 100 of these) and he said that the only other time he has seen a problem was an other guy with a Farmall.
I thought that the geometry of 3 point hitches was pretty standard across tractors and tractor manufactuters. Is that correct?
