Re: farmall cub gas tank dent
Posted by MarkinIN on July 29, 2006 at 16:36:40 from (207.40.84.183):
In Reply to: farmall cub gas tank dent posted by brad in ky on July 29, 2006 at 05:47:17:
I have tried the pin welding method and they weren't durable enough to pull that stiff metal. What I ended up doing was welding a 3/8" nut on the dent and then pulling it with a slide hammer. Then cut the nut off and grind the spot welds off and then putty the small area to make it smooth.
